Yale ERP040THN48TE082:
error code 16
Hello,
I was wondering if someone happens to know what this error code means. Its a erpo40tgn but i am not sure much more than that. I had purchased it used about 5 months ago. It currently displays this when I turn it on. The forklift and the mast are currently not operational with this error code. Any help would be appreciated. Thanks!
Drew
  • Posted 8 May 2020 14:50
  • Discussion started by drew_gabel
error code 16 is usually battery over voltage.you may have a bad PTC on the linecontactor. you may have a badly setup controller or an overcharging charger. leave truck with lights on for an hour or so to drain some voltage from the battery and see if it works
  • Posted 11 May 2020 20:49
  • Reply by stackerhacker
  • glasgow, United Kingdom
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
SMV (Konecranes) 16-900C
Hangcha FLDCXT160
Hyster
edition #1235 - 19 June 2025
