Error 31 - Potentiometer ?
Hello,
I have a problem with a Linde L12 - 379.
Everytime you start the truck an drive forward, the machine will operat normal. But if you want to drive back, it could happen that machine won`t drive. But only sometimes, it also could be that the truck works normal.
I have seen the Error 31 with Truck Doctor. I Changed the potentiomter (only the poti, not the hole unit) but it isn´t better. Sometimes it works, sometimes not.
Somebody any ideas?
Thanks a lot. Tom
  • Posted 7 Feb 2012 06:05
  • By tom_a
  • joined 7 Feb'12 - 1 message
  • Germany
Marco, i have a L12 364 battery light shows full power, key works and micro switch at the bottom of the handle just onto the drive motor works. I have no power or it seems to have no power to function anything from here, so i can not move or lift or anything. Seems like a emergency STOP switch somewhere, i am new to the machine so is there one on the grab handle? I have a multimeter just not sure where to start.
Thanks!!
  • Posted 23 Feb 2024 10:15
  • By Jamie_Laventure
  • joined 23 Feb'24 - 2 messages
  • Alberta, Canada
I assume your trouble consumer call of windows, we see equal trouble whilst pc consumer call set turkish characters. Exactly this indicates the communique among consumer and server is lost. Is the consumer supervisor strolling on equal PC with server?
  • Posted 26 Jan 2022 18:26
  • By William_Drake
  • joined 26 Jan'22 - 1 message
  • Idaho, United States
Hi all,
I have same trouble also. can any share the workshop document please.
  • Posted 12 Aug 2021 18:24
  • By Syed
  • joined 14 May'15 - 196 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
directional switch on column replace as a assembly
  • Posted 31 Oct 2014 10:06
  • By forkup
  • joined 25 Oct'14 - 11 messages
check both of micriswitch for forward and reverse in tiller control
  • Posted 12 Sep 2013 05:03
  • By darda_2
  • joined 12 Sep'13 - 14 messages
  • riyadh, Saudi Arabia
ideally set at 4.5v potencionetro this if it happens in the regulation will go and stand in range, I also change to avoid fallor button SW1 and SW2 and won in security for the future.
  • Posted 14 Apr 2012 07:54
  • By Vivira
  • joined 18 Nov'11 - 8 messages
  • murcia, Spain
Hi !
Check your tension in the middle of your potentiometer: 4.6 Volt is exatly to calibrate correctly.
Regards,
Marco - France
  • Posted 20 Mar 2012 08:15
  • By Depanneur06
  • joined 22 Mar'11 - 6 messages
  • Paris, France
edition #1281 - 14 May 2026
VETTER Industrie GmbH
Ncn 110TH
Ncn 110TH 2015
Terberg RT403
