error 1307 on efg 220
please can anyone help with the description of error 1307. it flashes on the machine along with 0181 at start up and machine doesn't perform self test.
  • Posted 6 Dec 2016 06:44
  • By Lomaxs
  • joined 28 Mar'14 - 20 messages
  • Lagos State, Nigeria
................Bamigbade
If supply cables from controller to drive motors are okay, if battery is okay, if terminals(controller, drive motors) are okay, it's most likely bad controller. To replace a controller you'lll need a tech with diagnostic software to set trucktype etc, unless you have truck with same options, same year etc.
  • Posted 3 Mar 2023 05:59
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
How Did you go with error 1307 ?
  • Posted 28 Feb 2023 20:48
  • By Haro
  • joined 25 May'22 - 9 messages
  • Victoria, Australia
Paul Scott
Any other reasoning for this error as I have same thing.
Can you explain where to check the wiring
And does this error give fluctuations in voltage ?
  • Posted 27 Feb 2023 20:59
  • By Haro
Paul Scott
check the isolation of the pump motor to chassis. or chassis wiring
Regards
  • Posted 4 Feb 2020 04:22
  • By edgardo_a
  • joined 26 Feb'09 - 28 messages
  • canelones, Uruguay
Oxford Ct, United States
Esie Cortez Esie Cortez
