Engine starts, but shuts off after about 10 seconds
I have a 2006 Genie S60 Boomlift With Deutz FL3 2011 engine, it tarts Every time, But shuts off every time after about 10 seconds
  • Posted 10 Jul 2024 02:23
  • By PIPELINE_Welder
  • joined 10 Jul'24 - 1 message
Signed
Swoop could be right.
However, if the 10 seconds is pretty consistent, then see your Oil Pressure or Switch.
The Other item that will shut this down would be a Over Heat signal.
Both of these will shut the system down through the ECM.
  • Posted 2 Aug 2024 01:44
  • By TailiftTom
  • joined 28 Jan'21 - 12 messages
  • Colorado, United States
Tom Edwards
3 days and no takers on this one? gee whizz...
ok PIPELINE_Welder i'll take a stab at it.
Generally if these Deutz engines won't run or has any issues running it has to do with something in the fuel system. Clogged fuel filter, pinched fuel supply line between the tank and the engine or possibly a bad fuel pump. It sounds like the pump may be weak to me and it just can't keep the fuel pressure up, it's just not pulling it from the tank well enough. Being a 2006 i'd say the diaphragm in the pump might be hard or cracked.
Try replacing the filter, if that doesn't help then put a fuel pump on it (if you don't find any issues with the supply line. (also there is a shut off valve on the fuel tank where the supply line comes out, make sure it is open all the way).
  • Posted 14 Jul 2024 04:03
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Taylor TX175
New - Sale & Hire
Unicarriers FD80-2
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
