Linde (& Baker) E25-01:
E25-01 91X336L01866 FAN ALARM
A customer has asked for assistance with a yellow alarm light on this trucks dash read out.
Model has a circular dial display with 4 yellow warning light segments, 2nd from left has a fan symbol this is on from power up and does not go out.
Any idea if this light refers to traction motor temp or hydraulics or both.
we have very little experience with this model local dealer doe not want to know machine.
any help appreciated.
Steve NZ
  • Posted 18 Jun 2015 13:59
  • Discussion started by stephen_f
  • Christchurch, New Zealand
https://www.aliexpress.com/item/1005001268095719.html?spm=a2g0o.productlist.0.0.6ab627b5lAnmDT&algo_pvid=182f8622-6f0b-49b6-a9c7-3c3ad3cb5804&algo_expid=182f8622-6f0b-49b6-a9c7-3c3ad3cb5804-0&btsid=0bb0622a16044247726887101ebe81&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
6
  • Posted 24 Nov 2020 01:41
  • Reply by JonoG
  • Uruguay
Jonathan Gill
Sorry Jono,that should have been 1100.00 dollars.
  • Posted 24 Nov 2020 01:35
  • Reply by Alberta
  • Alberta, Canada
truckshop@lonepinecolony.com
Where can I get a combined instrument for 11 dolars ?
  • Posted 24 Nov 2020 01:22
  • Reply by JonoG
  • Uruguay
Jonathan Gill
  • Reply by JonoG
  • Uruguay
Jonathan Gill
There are 3 temp sensors on these machines, check the resistance on these sensors first the information is in the service manual, if that tests good then check the continuity for the wires up your composit instrument quite easy to do, on our machine that all tested good and it turned out to be the composit instrument itself 1100.00 dollars Canadian dollars, our machine also was in limp mode with the fan on all the time but you should get the codes first.
  • Posted 12 Sep 2018 23:40
  • Modified 24 Nov 2020 01:36 by poster
  • Reply by Alberta
  • Alberta, Canada
Hi can i ask also. What is error code t220 pls need some idea
It simply means - "check the fan"
There are two of them on the font axle of 336-01
Check, if they work, the connections and plugs.
Should be simple.
  • Posted 26 Jun 2015 00:41
  • Reply by Karait
  • Poland
I know your deepest secret fear...
J.M.
UN Forklift FBR25NQC3
Hangcha CBD15
China
USD1,600
edition #1234 - 12 June 2025
UN Forklift FBT18NQZ1
Hitachi HX64B2
Toyota 02-8FD25
Toyota 02-8FD30
Your Focus
