E23 fault code & Panel lights flashing
Symptons:
E23 fault code and dash panel lights keep flashing. When I say light I mean all as in the red lights also.
Engine will not throttle up. Will slowly climb to 1800 rpms after a while.
Problem occured after lift was pressure washed.
Lift came in with overheating and trans issues.
Work performed so far.
Replaced throttle position sensor.
Replaced throttle accelerator at intake.
Performed swith on 2 sec and off 10 three times to clear system and relearn.
Tried another ECM from another lift.
Unit will not complete fast tas
Voltage at pin 5 is now.63 vlts
Showing 100 % at Throttle and Accelerator angle
Blowed out VCM and ECM connectors.
Blowed out visable wire connectors.
Checked for broken wires at map sensor
Hoping maybe someone has already run across this.
Any help of data on this is much appreciated.
  • Posted 22 Jun 2007 22:55
  • By Bass
  • joined 22 Jun'07 - 17 messages
Thanks swoop! Key dance worked...2 sec on 10 off 2 on..no more code!
  • Posted 6 Jun 2019 23:02
  • By JimmyBeam
  • joined 22 May'19 - 5 messages
  • Delaware, United States
did you ever figure out your e 23 fault code
  • Posted 30 Apr 2017 14:42
  • By satan007
  • joined 27 Apr'17 - 2 messages
  • Alberta, Canada
  • Posted 27 Apr 2017 22:07
  • By satan007
  • Alberta, Canada
of course the one thing i should have suggested first is just letting it dry out
sometimes compressed air still wont get in the right places, you just have to let it air dry out. get a heater and a fan and let it blow on the truck. That might help.
  • Posted 6 Dec 2012 08:28
Does anyone have a wiring schematic?
  • Posted 4 Dec 2012 05:35
  • By gene_l
  • joined 19 Jun'12 - 16 messages
the ETC relays can cause this problem also
ETC23 fault- Throttle sensor or wiring circuit is open or shorted. This malfunction occurs in the relation
between throttle position
sensors 1 and 2.
These sensors are internal to the TPS and are not servicable.
The most common issue causing this error is a broken wire at the TPS harness plug, usually finding the white/orange wire broken.
Also check the EGI relays in the relay box.
You can also try a TPS closed position learn
Turn ignition switch on and off
listen to the TPS and see if it is operating, you should hear it calibrate itself.
you can also try this learn proceedure
key on for 2 secs
key off for 10 secs
key on for 2 secs
this will calibrate the pedal position sensor also to the TPS
  • Posted 30 Nov 2012 22:00
Code E-23 is for Throttle Position sensor signal malfunction
  • Posted 30 Nov 2012 07:03
  • By kevin_t
Hey Did you figure it out yet? I got the same issue.
  • Posted 30 Nov 2012 06:00
  • By gene_l
wrong topic
  • Posted 30 Sep 2007 03:07
  • Modified 4 Oct 2007 20:24 by poster
  • By Bass
Sorry for my english...
check-up cable near connector, cable possibily damage interior.
  • Posted 29 Sep 2007 17:15
  • By maluccio_g
  • joined 29 Sep'07 - 17 messages
  • France, France
Broken wire at throttelsensor behind mixer white best of memory ohm fine but if you pull on it just a small amount you feal it strech.I know this is an old post but maybe it will help someone
  • Posted 9 Aug 2007 21:09
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Unicarriers FHGE35T5S
Terberg YT222
Esie Cortez Esie Cortez
