E107 and E108
Does any one have any info on these codes. My service manual does not show these codes, the jack turns on and as soon is you hit any function you hear a double click, and battery meter reads 100, thanks the codes are E107 and E108
  • Posted 4 Apr 2012 06:10
  • Modified 4 Apr 2012 06:11 by poster
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
There are a bunch of reports the the line contactors are mostly the source of this code.
  • Posted 5 Apr 2012 11:50
  • By rogeriwt
Thanks roge ill try checking my voltage and relay box
  • Posted 4 Apr 2012 08:14
  • By All Lift Tech
Meter on these truck don't always read correctly. I would start with a volt and load check of battery. If that is ok I would go after the main contactor ir the black relay box under the controller. They are know to go on these trucks.
  • Posted 4 Apr 2012 06:59
  • By rogeriwt
Linde Material Handling
