E-38 fault code
forklift runs great for 1 minute and 40 seconds then power is reduced significantly, I can shut it down then restart , it will react the same
  • Posted 25 Oct 2018 02:36
  • By Joelift
  • joined 24 Mar'15 - 6 messages
E-38 = LPG vaporizer diagnostic result signal
There is a MCFA service gram out on this code
it refers to there being an abnormally high fuel pressure detected by the fuel pressure sensor.
Additional troubleshooting information:
DTC E-38 may be set when the fuel pressure in the fuel piping/hose has been abnormally high for a predetermined amount of time. It may set if the sensing circuit is detected open.
-check the fuel pressure
Note:The fuel pressure it may read higher than 42kpa. The pressure can spike upward when you key on and off multiple times.
After cranking the engine begins or as the engine starts, the fuel pressure should begin to drop to 33kpa or lower depending on the year of the fuel system.
If it remains high then check the actual fuel pressure with a maximum 25psi guage, the guage must read 4 to 4.5psi average. if in excess of 5psi then begin looking for a high pressure leakage from the primary to secondary side of the vaporizer assembly.
I would also check the wire harness at the fuel pressure sensor and make sure none of the wires are broken.
If pressures are within the normal ranage then inspect the sensing voltage (above 5vdc) at the fuel pressure sensor.
2005 thru 2010 truck fuel sensor
At the connector on the fuel pressure sensor terminals
-pin 3 (blue/red wire) key on, 5v, engine running, 5v.
-pin 2 (white-green wire) key on 2.5v, engine running volts vary with LP pressure.
-pin 1 (black/red wire) negative
using ohm meter ohm resistance check between pin1 and pin2 must be between 40.4 to 45ohms.
2004 truck fuel sensor
-pin 2 (black/red wire) negative
-pin 1 (white-green wire) key on 2.5v, engine running volts vary with LP pressure.
If the voltage is normal then replace the fuel pressure sensor.
  • Posted 25 Oct 2018 14:12
  • Modified 25 Oct 2018 14:24 by poster
what should I be looking for
  • Posted 25 Oct 2018 02:55
  • By Joelift
ASSET FINANCE
Nov 2025
October 8-10, 2025 - Lucca, Italy
June 17-20, 2026 - Bangkok Thailand, Thailand
August 19-21, 2026 - Bangkok Thailand, Thailand
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
Bolzoni SpA (Group HQ)
Philadelphia, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
