drive problem, manual
have a M40D cat, s/n 4WC01746. No manual.
Have run the diagnostics and everything is ok. The problem is when you step on the accelerator pedal, unit creeps, then takes off. Happens same way forward or reverse.
Checked the drive motor, SCRs, and replaced the throttle control.
Would like a repair manual or if anyone has had this problem
  • Posted 26 Nov 2014 23:07
  • By howard_r
  • joined 28 Jul'12 - 9 messages
  • Missouri, United States
good deal
yep that would of been my first suggestion, to check connections.
  • Posted 29 Nov 2014 00:25
found the problem. the logic card was not receiving one of the inputs from the throttle box due to corrosion. cleaned the contacts of corrosion. unit runs fine. thank you for your response!!!
  • Posted 28 Nov 2014 23:56
  • By howard_r
does this condition occur all the time (cold or hot)?
or only happen after the truck has run and gotten hot?
  • Posted 28 Nov 2014 03:15
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
