Dreaded p04/f04 after pressure washing
I've been coming on here for at least 12 years but this is my first post!! Got a fg30n serial af13f00258 sold and was prepping to go out-machine ran perfect no codes..... but I decided to pressure wash it prior to servicing and doing other maintenance... it got wet and would not crank threw a code e38....brought it inside pulled all the electronic connectors blew it out and put fans on the machine-let it sit overnight and came in and did the other things it needed-plugged everything up and now I have a no start condition with p04/f04!! I've checked all connections, swapped relay and fuse boxes, vcm, cluster, ecm, (with correct part numbers off known good trucks) cleaned and checked grounds, etc I'm at a loss.....I think a wire broke inside the insulation when I was disconnecting everything or something! Does anyone have any tech info on this or "tricks" I don't know what wires to check for resistance and voltage etc -I've got an unicarrier truck sitting here with 2k hrs with the same problem....
  • Posted 25 Jan 2024 23:46
  • By Palmer
  • joined 4 May'23 - 1 message
DP
Taylor T520S
Toyota 02-8FD25
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
