Drain fluids on H40FT
How to drain all fluids from forklift (propane fueled)? Drain port locations for the fluids and any lessons learned? Also, is there a manual available with this information? I have limited forklift mechanics experience, more driving experience. Thank you in advance for your help. Any guidance is much appreciated.
  • Posted 11 Jul 2025 05:47
  • By Dustin_Barnes
  • joined 11 Jul'25 - 1 message
Dustin Barnes
And don't forget to drain radiator as well as engine coolant
  • Posted 12 Sep 2025 08:11
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
Dustin,
The engine will have a drain plug toward the middle of the lift as the engine is mounted backwards. The transmission has a plug in about the same location. Hydraulic tank drain should be on right side at the bottom of the tank. You will have hydraulic oil in hoses and cylinders that will need to be removed to remove all oil. The front differential has a plug t the bottom. Good Luck
  • Posted 12 Sep 2025 06:10
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
Sue Tomic Sue Tomic
Taylor T650L
Crown WP302020
