Distributor Fastener.
Can't get the Fastener out that holds the Distributor down. 3 cyl. engine. Distributor s Have one bolt that holds them to the engine block.
  • Posted 23 Dec 2019 13:04
  • Modified 26 Dec 2019 12:14 by poster
  • By Prancer
  • joined 12 Oct'13 - 48 messages
berwinten@msn.com
ahhh, sorry i was mistaken, i was thinking it was the cap. Some of them can be tricky :o)
Yeah that sounds a bit odd, most distributors have either a bracket with a bolt holding them down or some sort of clamp on the older ones i remember.
If this is a plug as you say can it be removed? See if that frees it up? It could be like a detent type plug that works like a set screw?
  • Posted 26 Dec 2019 13:42
I removed the cap ok, It is the Distributor assy. there is no bolt , looks like a plug or something.
  • Posted 26 Dec 2019 12:06
  • By Prancer
berwinten@msn.com
it's either going to be a clip or a screw that hold the cap on.
the clip is obvious, once you pop the clip off the cap flange it falls out of the way
as for the screw type, alot of caps that use the screw method have a retainer holding the screw onto the cap so it wont fall out, some are simply just a rod with a bent end to catch underneath on a ledge so when you turn the screw it just unlocks.
If your having trouble getting the cap off make sure the screw is actually all the way out, if it is the bent rod type make sure it is off of the ledge it catches, otherwise it may just be a tight fit and bumping it to one side may get it to come off.
  • Posted 24 Dec 2019 05:05
  • Modified 24 Dec 2019 05:07 by poster
SMV (Konecranes) 4531CC5
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
St. Louis, MO, United States
Uxbridge, Canada
Evansville, IN, United States
Daleville, IN, United States
Crown Equipment celebrates 80 years New Bremen, OH, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Crown CG33P5
TCM FHD105Z
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
CEO, MHEDA
