Yale GLP20SVX:
Dead forklift: fault codes 677-3 and 2000-12
Hi all. Fault codes 677-3 and 2000-12 are displayed. Engine doesn't starts, no power on starter relay coil. What does these codes means? 667-3 is probably something with starter relay driver... but 2000-12?
Another problem, when fuse F6 is in, the horn sounds continously when the battery is connected. There are no shorted wires from horn button.
  • Posted 20 Jul 2011 16:06
  • Discussion started by ArtB
  • Śląsk, Poland
I have had a weak battery give this code as well as an over charging alternator.
  • Posted 22 Feb 2019 07:38
  • Reply by PESLLC
  • fl
DC
The horn on these trucks are three wire. There is a batt. pos. and a batt. neg. And a signal wire from the VSM. Check the wiring at the horn and test the out put wire for a pos. signal from the vsm. If no signal replace the horn. If there is a signal and the horn button is not stuck you have a defective vsm.
  • Posted 27 May 2016 05:11
  • Reply by BREWSKI
677-3 is a voltage high on the driver output. Check the wiring for shorts to battery pos. Is this keyless start truck? If it is check the disconnect switch under the hood.
  • Posted 27 May 2016 05:08
  • Reply by BREWSKI
Check 20amp fuse in the box next to battery. If that has blown you wont get any gas through the chamber an no spark.
  • Posted 21 May 2016 17:37
  • Reply by luke_m
  • Bedfordshire, United Kingdom
ArtB,
You have a Canbus Error that may be inhibbiting the vsm starter driver.
Clear the error log and see if the truck now starts,
Titus
  • Posted 22 Jul 2011 05:09
  • Reply by Titus
Hangcha CBD15
China
USD1,600
JLG 450AJ
JLG 450AJ 2017
Flesherton, Ontario, Canada
