Dash display going out
Any suggestions, we have replaced the dash display twice in the last year, its seems to be going out again, lights sometimes, then most time the background illumination is out and can only slightlty see the fonts, upon start up, works fine then in a few,goes out, checked 5 and 12 volt readings all good, has anyone experienced this, also wire diagram does not show whether key pad or controller supplies voltage?
  • Posted 7 Sep 2016 09:27
  • By steppednit
  • joined 18 Oct'13 - 50 messages
  • Tennessee, United States
the display has a contrast potentiometer to adjust the display, you can turned clockwise with small screw driver if that doesn't work you must replaced the display, no other way!
  • Posted 25 May 2020 00:42
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
having similar issues with our UFS250. Check the ribbon cable connection where it plugs in to the TCU (big blackbox. there is only one 14 conductor ribbon on ours) we have had problems with the connector not being seated tightly on the ribbon itself, leading to loose connections. I have reseated ours, and it worked, but the connection was never intended to be a dynamic cable (i.e. moves when the dash board is flipped up. it works loose after a few times opening and closing the dash). Our display has finally crapped out. I have a new chunk of ribbon coming and new connectors where it connects to LCD card, and d-sub15 connector at TCU. I will post if this solves anything - hopefully it will help your task if you are still chasing it down. I will also inspect the TCU side of the d-sub15 connector to see if a pin has lost tension and is not getting a good contact. If you have solved yours, what did you end up doing? [short of replacing a $1700 display assembly, or a $5500 TCU.] These trucks are great when they work, but sweet mother-of-pearl, the parts give me indigestion.
  • Posted 23 May 2020 01:20
  • Modified 23 May 2020 01:22 by poster
  • By SmokedChops
  • joined 18 Jul'17 - 20 messages
  • Iowa, United States
here my email look me up [email address removed] I can help with that problem,
  • Posted 29 Nov 2016 23:37
  • By GUANAJUATO
I believe it is a 2010, it works on initial start up then begins to flicker and go dark after 5 minutes,replace the display unit and works well for a week and starts going blank again
  • Posted 26 Nov 2016 00:32
  • By steppednit
what year is the truck?
  • Posted 13 Sep 2016 21:41
  • By GUANAJUATO
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Lift Tek Elecar
