Daewoo G25E-DF Transmission
Does anyone have any specs or transmission service manual pages for this unit. Looking for pressures and diagnostic information. Thanks.
  • Posted 1 Feb 2013 08:06
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
lumberjacks right any pressure problems check the small filter in the control vavles on top of transmisson.
Remove top of the transmisson and remove big allan key plug about 19mm. think its in the centre of the block pull out the vavle which has a small filter inside about 2mm-3mm and just see if its loose if so tighten and rebuild.
If it is loose will give poor drive both directions and had it once when only in forward.
i sure someone will explain this better but will point you in the right direction.
i have also had clutch plates burnt out on a doosan which was less than a year old.
  • Posted 2 Feb 2013 05:24
  • By bing098
  • joined 2 Mar'12 - 40 messages
  • Kent, United Kingdom
If memory serves, there might be a problem with a a white plastic strainer at the top of the assembly.... something about an "o" ring causing a poor fit.
Maybe someone has a Service Bulletin on this?
  • Posted 2 Feb 2013 03:29
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
UN Forklift FD50T-NJB3
JLG G12-55A
Linde Material Handling
JLG G12-55A
