current transformer / linde
Hello ,
LINDE , E16Z-02
Please explain me , how to test a CT (3903505214) individually ?
What will be the effect of the Truck if CT is damaged ??
  • Posted 1 May 2013 23:40
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
3 options:
pin 2 is always high: relays energize but nu pulse
pin 2 is always low: Current way to high, fuse blows when pulling
pin 2 floats: low pulse, often when you touch the wire the pulsing goes up and down.
  • Posted 5 May 2013 06:15
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
This reference corresponds to current sensor for tration motors.
It's feeded wtih 15v from 1A2 traction controller (yellow and green wires) and send analogic signal from yellow/green wire depending on the current flowing.
1X6 connector;
pin 1-- +15v
pin 2-- output signal
pin 3-- 0v
Output signal:
motor current 0A = output signal 7,5v
motor current 100A = output signal 8v
motor current 200A = output signal 8,5v
For each 100A motors increase in current, the output voltage changes by 0,5v
Regards
  • Posted 2 May 2013 00:40
  • Modified 2 May 2013 00:52 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Muncie, IN, United States
Elwell-Parker ESI500-36
Kalmar-Ac P100CXD
