Crown SP3020-30 S/N 1A193673 Travel issues
We have a Crown SP3020 that is having travel issues. The drive wheel barely turns under full throttle and sometimes will not start at all. No codes. I checked the accel voltages at the EV100 ZX board and they are within spec. I also checked all three of the height switches at the distribution board, all were good, I thought maybe one of them could be bad and limiting travel speed. The only codes stored in the system were 208 and 217 both relating to a bad steer motor and steer encoder, both of them have been replaced and seem to be working fine, dash leds and wheel alignment are correct. Unfortunately our service terminal is not working correctly so I can not plug into the system check anything. Any help would be greatly appreciated.
  • Posted 6 Apr 2016 01:43
  • Discussion started by RAFARMER
rafarmerjr@gmail.com
hi every one
i also have trouble in my SP3020
i have trouble in my crown SP3020 event code 215 when i switching key the traction drive wheel should be rotating to sense the sensor and complete cycle but no. they have event code 215 which particular parts is the problem?
thanks in advance for someone responding..
  • Posted 18 Sep 2019 18:53
  • Reply by jonathan_l
  • Jeddah, Saudi Arabia
Im a hero
From what you described, might be a bad #1 rectifier.
  • Posted 8 Apr 2016 09:42
  • Reply by LaGrange
  • Missouri, United States
If the Directional Contactor tips are closing and remain closed, that tells me that the Brake Switch and Directional Switches are working.
If the Drive Tire/ Drive Motor do not turn, when the tips are remaining closed, there might be a problem with the Accelerator Potentiometer.
The Pot itself might be bad. You'll have to make sure that all the wires for the Pot are connected, where they belong, and are supplying volts to the Pot.
If you need more help, let me know.
  • Posted 8 Apr 2016 09:41
  • Reply by LaGrange
Thank you popeye for the response. I had already blocked the truck up and checked the brake, it was fine. The motor speed never got to the point that the 1A would come in on its own. I had an idea that it might of been the SCR system that was the issue and had a parts truck here that had all the parts I needed so I pulled the whole assembly and replaced it. That did the trick and all is good now. when I get time I will pull the old SCR system apart and see what component was at fault and post here so if anyone else has this issue, it might be of help.
Thanks again
RAF
  • Posted 8 Apr 2016 03:05
  • Reply by RAFARMER
Make sure the brakes are releasing first. If they are first turn on the truck then jack up and block the power unit try traveling and see if the 1A contactor pulls in which bypasses all the transistors and supplies battery voltage to motor. If it does pull in and speed never goes up then you know its cables or motor if not then you are into the SCR system and a possible card or transistor
  • Posted 6 Apr 2016 09:11
  • Reply by popeye
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
