Crown SC3000
How to adjust steering potmeter Crown SC3000 tree wheel 3018 year 1999
Maybe pdf file with discription of it!!!!
Kindly regards
John.
  • Posted 12 Aug 2009 03:58
  • Discussion started by johngen
  • NB, Netherlands
You can do it w/o the svc. terminal. Jack the truck up, loosen the set screw and with the unit powered up, you can manually with a pry bar rotate the steer/ drive motor untill the 2 hash marks are lined up. Now while the truck is on the jack and running pull the encoder and rotate the pot so you can see the the drive unit turn back and forth to ensure it works. bring the steering back to center on the hash mark, install the pot/encoder back in and tighten the set screw, lower the truck to the ground and drive it. if it codes again replace the steer encoder. Very rarley will it be the encoder behind the steer til;ler assy. But, it has been known to happen. - Jeff
  • Posted 25 Sep 2009 23:16
  • Reply by Smoked
  • Missouri, United States
ROYPOW
UN Forklift FGL35T
Taylor T650L
