That only works on a 5000 series and above. Older than that you must add a sprocket and chain as described above as the torque generator attaches directly to the manifold block.
Quick and easy way is just to change the hydraulic hoses from port A to port B and vice versa at the steering valve.
you have to know if you have forward or reverse, rite now. just have to add or delete a sprocket and chain.it is wound all the way around for rev. forw. needs sprocket, wound to the inner of new sprocket. :)
hi, garland. i sent you some info that can help.
adolfo.g
