Counterweight removal help!
Working on a late 1960s Yale forklift model#: G51C040NFS071 and we cannot figure out how to remove the counterweight. The reason we are trying to remove it is because it started to separate from the rest of the machine at the top of the counterweight. We removed (actually broke off) the 1" bolt at the back lower portion of the counterweight (big bolt that goes in the hole in the counterweight just underneath the oval slot for the hitch pin). The counterweight is now slightly loose but will not break loose from the machine. Are there other fasteners or what are we doing wrong? Thanks!
  • Posted 19 Sep 2018 09:11
  • By Teacher
  • joined 15 Sep'16 - 8 messages
  • Wisconsin, United States
So now that we have the counterweight off we found an eccentric bushing (round bushing with offset hole in it) in the front of the bolt hole in the counterweight. Is it there due to manufacturing differences between the counterweight and the truck frame?
  • Posted 24 Sep 2018 05:31
  • By Teacher
Thanks for the help! We were able to get the counterweight off today. What was holding us up was that when the bolt broke about 1/2" of it was still protruding into the counterweights hole. We drilled into what was still protruding with progressively bigger drill bits until it weakened enough to let the counterweight come loose. I was worried we were missing a fasteners somewhere. Reading your explanation helped us figure out how it was attached. Thanks again!
  • Posted 20 Sep 2018 11:46
  • By Teacher
There are V shaped saddles on the top that the weight fits into so just lift the weight about 2-3" and then it will come off.
  • Posted 19 Sep 2018 22:42
edition #1281 - 14 May 2026
Ncn 85TH
Ncn 85TH 2014
Morooka MFD20
Nils Altrogge Nils Altrogge
