Raymond 540-OPC30TT:
Code G2
Turn key switch on and goes through self test ok. Step on dead man pedal and code appears. Lift/lower works but not drive or steering.
  • Posted 19 Jun 2020 04:29
  • Discussion started by techtrnr
Pueden ser dos cosas,el sensor o arnés abierto(cable roto que a simple vista lo se aprecia...).saludos!!
  • Posted 6 Feb 2021 00:24
  • Reply by lorito
  • Mexico
alex
Most likely steer feed back pot, or prox sensor
  • Posted 4 Feb 2021 07:18
  • Reply by 1sharpdog
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Debe de ser un circuito abierto del arnés..
Literal translation...It must be an open circuit harness.
  • Posted 5 Sep 2020 06:10
  • Modified 5 Sep 2020 08:45 by administrator
  • Reply by lorito
  • Mexico
alex
Does the steer wheel auto center when you step on the deadman pedal? If not, the gear shaft at the bottom of the steer motor may be sheared off on top of the gear. Seen it a few times.
  • Posted 5 Sep 2020 04:29
  • Reply by LiftGuy
  • Virginia, United States
edition #1228 - 1 May 2025
Taylor TX330S
USD159,500
Terberg YT220
Crown CG33P5
Toyota 8FD45
Bolzoni SpA (Group HQ)
Louisville, KY, United States
Dubuque, IA, United States
