code f4
Is Code f4 low battery voltage? ec25k a3ec230413
  • Posted 11 Oct 2014 09:49
  • Modified 11 Oct 2014 09:51 by poster
  • By jerry_c
  • joined 5 Oct'10 - 26 messages
you're welcome
can i presume you found the problem?
blown fuse?
  • Posted 15 Oct 2014 11:02
Thank you swoop. I can see from the other discdussions that your are a professional at your trade. jc
  • Posted 15 Oct 2014 05:50
  • By jerry_c
f4 is not a normal status (error) code on these GE systems
error codes are generally displayed by a -xx (traction) or -**** (pump) code format. No letters
If you are getting a f4 i would check the fuses in the rear panel and make sure none of them are blown.
FU4 on the main control panel is the main 350A or 500A (depending on what controller it has in it) fuse connected to the line contactor circuit buss.
Check that and make sure it's not blown or badly connected.
check for burning etc.
  • Posted 13 Oct 2014 04:09
  • Modified 13 Oct 2014 04:09 by poster
May CapEx Index falls Washington, DC, United States
Tampa Florida, United States
