Cat Lift Trucks (& Caterpillar) P5000:
Code E-36
I have a unit that is displaying the code of e-36 i know that that is a lpg low presh sensor code. I checked the LPG presh coming out of the vaporizer and it was about 34KPA. I do not have a laptop to hook up to the unit, and it does not have the OBDII conector on the truck. what could be the issue?
  • Posted 13 Oct 2017 06:09
  • Discussion started by sbhbrett
Check your inlet screen on the mixer where the propane comes in from the vaporizor..there is a small screen that can get clogged woth debris...be careful,it is held in with a small clip and the screen can rip easily
  • Posted 1 Dec 2017 04:20
  • Reply by kevin_t
DTC E36--LPG Fuel Pressure sensor diagnostic result signal.
Check fuel pressure with Diagnozer. If pressure is reading low then retest pressures using actual gauges to confirm pressure. If actually low, check fuel lock and filter (clean).
If no reading, check failed main C or EGI relay, blown fuse, broken wire at the sensor, blocked filter screen in the injector holder.
  • Posted 1 Dec 2017 01:31
  • Reply by Bacon123
VETTER Industrie GmbH
edition #1229 - 8 May 2025
Hangcha 80XENS
Flesherton, Ontario, Canada
Hangcha CBD15
China
USD1,600
