Raymond 4700:
Code 93
Would anyone have information on the Raymond (4700) series 4 wheel sit-down? Unit is manufactured (I believe) from a company in Italy (Cesab). Control system looks to be acceptable by laptop only and not with a handset like the (Zapi system). Customer claims to shutdown and displays code 93. I could never get the unit to fail.
  • Posted 4 Dec 2010 12:14
  • Discussion started by Miloslouis
Thanks RayTech....I appreciate the information......This will get me going in the right direction. The local Raymond dealer was no help and to be honest.... from what I'm told this series of truck they don't see too much!! Thanks again!
  • Posted 6 Dec 2010 06:23
  • Reply by Miloslouis
Hi Miloslouis,
Check the static strap, some were missing and others were bolted to painted surface making them useless.
You will need "flashware" to access vehicle manager as it controls all, unlike the Cesab system.
Code 93: Communication Error
Detected By The VM
The VM has not received information
from the Operator Display.
Check power to TPA, PPA, VM and HCB, and Operator
Display. Check communication wires between VM and
Display for continuity and shorts to frame. If OK, replace
94 Code 94: Internal Fault
The VM has detected an internal fault.
Replace the VM.
  • Posted 4 Dec 2010 23:54
  • Reply by EasiTek
Hitachi HX64B2
Hangcha CBD15
China
USD1,600
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
