Code 33025
I have a Yale forklift electric That two or three times a month throw this code 33025 Unit will completely shut down but if I recycle the key on off it will turn right back on and work normal Till it throw The code again A week later or so Any help would be appreciated thanks
  • Posted 2 Jun 2022 22:39
  • By Tony_Aguilar
  • joined 14 Apr'22 - 12 messages
33025 is generally a nuisance code or a false lead. The description is VSM to display but that doesn't mean there was an actual problem with the CAN wiring. What usually happens is the Hilo shuts down for some other reason and the 33025 is a byproduct of the shutdown. By all means check connections and CAN wiring. I suggest removing the display and doing a resistance test from the face of the display connector while moving the harness at various places. But if you have telemetry with timeouts set, that code can also be a byproduct of the telemetry system. DO NOT jam your probes into the connector sockets. Keep some wires around with the matching terminal ends to plug into the display connector so you can do a hands free resistance test. The number of techs I work with that make more problems by jamming their leads where they don't belong is ridiculous. Don't be that guy!
  • Posted 11 Jan 2025 02:21
  • Modified 11 Jan 2025 02:26 by poster
  • By Kevin_Lancaster
  • joined 2 Nov'21 - 3 messages
  • Michigan, United States
Check the water levels of the battery cells, if it is a lead acid battery.
Battery maintenance gets ignored way too often.
Low voltage causes weird problems to occur.
  • Posted 4 Jun 2022 16:13
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Thanks
  • Posted 3 Jun 2022 01:50
  • By Tony_Aguilar
33025 is a CAN communication failure between the VSM and Display. I'd check all wires for damage or loose contact. Dielectric grease on all connections wouldn't be a bad idea. Other than that, I'd just live with it until the problem becomes worse and easier to find.
You might get clues to where the problem is by manipulating the wires and connectors to see if you can make it malfunction.
  • Posted 3 Jun 2022 01:37
  • By lumberjack
  • joined 27 Jul'07 - 192 messages
  • Maryland, United States
Stu Jacover Stu Jacover
Chief executive officer, TVH
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
SMV (Konecranes) 33-1200C
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Libiao Robotics
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
