Raymond 560-OPC30TT:
Code 2H -intermittant-
I my experience if you have this code 2H intermittently its usually one of two things. First check to see if the encoder has a linear count using I19 to see it. Try turning while driving to see if unit cuts out and gives code 2H. If it does check the wire harness for the drive motor encoder. Usually the are zip ties so tightly to the drive motor cable that sometimes loosening up the wire harness fixes the issue. If things look good then it could be a drive motor speed sensor. What I do if its an intermittent issue that i can not duplicate I replace the drive motor speed sensor and the wire harness for it and never hear from the customer again :)
  • Posted 25 Jul 2019 01:07
  • Discussion started by tyler_d
Hello, dear, I would like to know how you solved the problem of the 2H code. I have REACH TRUCK 45TT , the probeles has when it presses and accelerates and you have to release the pedal (DEADMAN) so that the machine stops emergency because it can crash, thanks
Airman ENCL045
Nagano NUZ090D
GemOne
