Raymond SA SWINGREACH:
code 29
Hard code 29 on my Sa , tried the speed sensor and activator any help is welcome
  • Posted 21 Jul 2017 06:16
  • Discussion started by milford
  • Alberta, Canada
29 typically is a broken brake wire. Repair it then brake releases and code will clear after the truck sees movement for a while. You could have an issue with the speed feedback sensor on top of the brake or the wiring to it or the disc gap may be too large/gets large as the armature rises from worn motor bearing.
Also I have had a vfc card lock 29 on. New vfc was req'd. Only one instance of that.
  • Posted 20 Sep 2017 06:06
  • Reply by stam
Sorry Stan yes it does ,
  • Posted 20 Sep 2017 01:09
  • Reply by milford
  • Alberta, Canada
Is the brake releasing? Does it move at all?
  • Posted 21 Jul 2017 08:06
  • Reply by stam
Enforcer FD50T-MMA
Unicarriers FHGE35T5S
edition #1228 - 1 May 2025
Toyota 8FBE20U
Flesherton, Ontario, Canada
Terberg YT220
Load Lifter 2414-8G
Hangcha FLDCXT160
