Clark TM15S
The Clark lift is showing a code 02. System is EV100. Can anyone supply me with a code listing? Thanks for the help.
  • Posted 4 Mar 2010 05:45
  • Discussion started by garland_m
  • Virginia, United States
Work Hard and Fish Long
Hi garland_m
The 02 fault code is usually caused by a faulty direction switch, a short in the direction switch wiring(between TB2 and TB5 logic wires) or a faulty logic (which can be checked by disconnecting the wire on the TB5 logic terminal and checking that the voltage at the terminal is less than 60% of battery voltage) if theTB5 terminal voltage is higher than 60% with the wire off then the logic is faulty.
Regards
Shane
  • Posted 4 Mar 2010 18:51
  • Reply by controlelectric
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
VETTER Forks, Inc.
Zhejiang UN Forklift Co., Ltd
