Check engine light
GC35S Serial # P500124
This machine has a check engine light on, cannot communicate with laptop, and when we try to do the flash codes it does not show it has any codes. After clearing light (by using pedal trick) as soon as we crank it over the light comes back on, but still wont show a stored code?? Anyone have any ideas? I am starting to lean towards the ECU....???
  • Posted 10 Jun 2016 07:25
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
Measure the resistance value across the two wires on the diagnostic port connector where you hook up the laptop. There should be around 120 ohms, if not there is a bad/broken resistor in the harness. It is soldered into the harness about 6-10" from that connector.
  • Posted 9 Jul 2016 05:06
  • By sirthor1881
  • joined 15 Mar'11 - 24 messages
yes got it fixed. Ended up finding broken wire between ecu and connector for laptop, laptop showed oxygen sensor code, replaced and o.k. now.
Pedal trick is koeo (key on engine off) accel pedal to the floor and fully released 3 times in 3 seconds and it will do "flash codes". To clear codes do pedal dance 10 times within 10 seconds, and code should clear.
Thanks.
  • Posted 7 Jul 2016 22:45
  • By JAYS
Hi,
did you manage to fix this? Also what is the pedal trick?
  • Posted 7 Jul 2016 17:14
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Maxlion MTF25-60-2WD
Toyota 3FD100
Toyota 3FD100
