Cat M50D no lift
Hi everyone! Got an issue where this machine won't lift. everything ohms to the card good. No P contactor pull in. PS ramps the pump so I'm assuming the transistor and the diode are both good. Anyone got a book? SN is 6GC01293. I suspect the lift valve card but not 100% sure.
Thanks!
  • Posted 17 Oct 2012 00:35
  • Modified 17 Oct 2012 00:37 by poster
  • By justinm
bring a magnifying glass, if I remember correctly, the table that tells which is what should be in the corner of the decal of the schematic that was on the door when you open the controller compartment,
Is this is one with an 'LDC', controller?
  • Posted 19 Oct 2012 20:51
Hi Ed!
Yup. Didn't have the manual onsite. Going back to check it out.
  • Posted 19 Oct 2012 09:44
  • By justinm
Can't you run through the inputs tests with the DRS switch, on this truck?.
  • Posted 17 Oct 2012 10:54
SMV (Konecranes) 4632CC5
TCM FHD105Z
GemOne
