Cat F30
hello everyone i need some ideas on this Cat F30 serial # 5DB1612
its an intermittent problem, when you are traveling and move the dir lever from fwd to N the truck will just die, you can recycle the key switch and the unit takes right off.
also if you are traveling in either direction and raise your foot off the accel pedal quickly the unit dies also. but if you raise your foot slowly it will not fault out.
any ideas would be appreciated
oh yea it shows code F when it fails
  • Posted 8 Apr 2011 02:23
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
F - Drive problem; both an F"r" and an F"L" problem
together. Is possible contactor tips. Is posible diag, acelerator, and sensor steering. In logic Card, Switch in position diag, Fuse principal out, and chekin acelerator and steering. Pass check with switch run-diag.
  • Posted 9 Apr 2011 03:27
  • By joram_s
  • joined 5 Feb'11 - 117 messages
  • madrid, Spain
Email soyjoram@gmaildotcom
Hi Bruce
If this is anything like the old F35 cat electrics. Then from what you have described could be a foot pedal fault. Inside the foot pedal assembly they use Opto sensors and sometimes a good clean out with a brush and some electrical cleaner can resolve the issue.
Other times it could be related to the steer sensor card which sits under the old f35 controller panel in the back which also uses opto sensors to determine the drive motor lockouts etc.
  • Posted 8 Apr 2011 04:43
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hangcha FLDCXT160
Crown RD572513TT6860R
Yale Lift Truck Technologies
