CAT E 6000 Code 65
Serial A4EC-341063.
Can someone describe this error code to fix it.
Thanks for your help.
  • Posted 24 Apr 2015 04:21
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
E1200? or E12000?
on the E12000 the codes:
-64 means the line driver input (P2-17) is less that 12% of battery volts.
-65 means the line coil is too high during the run mode.
i would check the line contactor.
check the coil resistance, should measure 59ohm for 36/48v trucks, 161ohm for 80v trucks. also check the signal on that wire 17 on P2 connector and make sure there is a signal when the truck is turned on.
if all that checks out ok then you have a bad controller unit.
  • Posted 7 Oct 2023 08:13
Swoop modelE1200 has a 64 and 65 code can you point that direction
Tanks
  • Posted 7 Oct 2023 07:18
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
DTC 65
Pump Inverter Fault
see your mail for information on how to troubleshoot this
  • Posted 24 Apr 2015 21:59
Toyota 8FG25
Linde C4230TL5
Toyota 8FG25
Linde C4230TL5
Lift Tek Elecar
Toyota 8FG25
Linde C4230TL5
