Calibrating Throttle Pot
Can anybody provide instructions on calibrating the throttle pot after you install a new one? Thanks.
  • Posted 23 Oct 2013 06:29
  • By ATK1
  • joined 27 Jan'12 - 75 messages
  • South Dakota, United States
allenk@ntlifts.com
I appreciate the info. Thank you.
  • Posted 23 Oct 2013 22:28
  • By ATK1
allenk@ntlifts.com
can you clarify which one you replaced?
there are throttle sensors (which are in the throttle body and are not adjustable)
and there are pedal position sensors (which are in the pedal control and are adjustable)
now as kevin stated those figures are for the pedal position sensors
i looked in the p7000 engine control manual and it shows this:
key on (engine stopped)pedal fully depressed:
sensor1: 4.2v (terminal 106)
sensor2: 2v (terminal 98)
key on (engine stopped) pedal fully released
sensor1: 0.6v (terminal 106)
sensor2: 0.3v (terminal 98)
not sure where he got his info from but appears to be reversed, maybe dyslexia..it happens ;o)
having a serial number of the truck might be helpful to some degree but as for this setting it probably isnt going to change much between the models and years.
  • Posted 23 Oct 2013 20:51
  • Modified 23 Oct 2013 21:06 by poster
Thank you very much.
  • Posted 23 Oct 2013 07:50
  • By ATK1
allenk@ntlifts.com
I was wrong,found what you are looking for,don't have the pinout info but will look for it,there are two sensors in the assembly,info is as follows:
sensor 1:
At idle......67V-.87V
Keyon engine off/ Pedal depressed:.67-.87V
KOEO/ pedal released: 4.4-4.6 V
Sensor 2:
Idle......335-.435V
KOEO/Pedal Depressed:.335-.435 V
KOEO Pedal released: 2.2-2.3 V
  • Posted 23 Oct 2013 07:32
  • By kevin_t
Nothing in the manual on that...........
  • Posted 23 Oct 2013 07:21
  • By kevin_t
That is for learning if I recall. But I believe what I am looking for is voltages when pedal is in different positions to get the sensor positioned correctly. Thanks.
  • Posted 23 Oct 2013 07:14
  • By ATK1
allenk@ntlifts.com
turn key on,wait at least 2 seconds
Turn key off wait at least 10 seconds
Turn key back on and wait at least 2 seconds and learning will be done.......
  • Posted 23 Oct 2013 07:03
  • By kevin_t
The pedal pot. (Position sensor)
  • Posted 23 Oct 2013 06:58
  • By ATK1
allenk@ntlifts.com
Which pot you asking about,the accelerator pedal pot or the throttle body pots??
  • Posted 23 Oct 2013 06:57
  • By kevin_t
edition #1285 - 11 June 2026
US forklift tariffs now 15% Washington, DC, United States
Bolzoni SpA (Group HQ)
