C500 50 hot starting
I have a Clark c500-50 lpg built in 1983. It starts fine from cold but when it's been running and the engine is hot it struggles to restart. It seems to be turning over fast enough.
Having taken advice I have changed the coil and also changed the HT leads. This doesn't seem to have made much difference.
I was also advised it may be a fuel issue and that if a little easy start in the air intake solved the issue it would be a gas supply problem. But that doesn't make much difference either.
Any suggestions??
  • Posted 23 Jul 2020 03:15
  • By JPS000
  • joined 6 May'20 - 2 messages
  • Suffolk, United Kingdom
You may want to take a compression test valves may be tight,good luck
  • Posted 23 Jul 2020 22:42
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
GemOne
Big Joe PDR30-154
USD7,500
Enforcer FLBAXT25
GemOne
