C016 and E085 errors - help
When you drive slow no error codes come up but when increasing to full speed C016 and E085 errors come up and the unit abruptly stops. You have to turn the power off and back on in order to drive again but the same thing happens.
Could bad batteries cause this? Batteries are currently weak.
Any help with these error codes would be appreciated.
  • Posted 11 Nov 2015 06:45
  • By MERC
  • joined 11 Nov'15 - 5 messages
  • Missouri, United States
sorry error 84 is speed sensor, error 85 refers to low power voltage. If battery is weak then I would suggest connect a good battery first, also check power connections to controller and line contact tips.
C016 refers to main controller
  • Posted 12 Nov 2015 07:31
  • Modified 12 Nov 2015 07:31 by poster
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Where is this sensor located on the pallet jack. Thanks for your help.
  • Posted 11 Nov 2015 11:42
  • By MERC
Faulty speed sensor, also check connection to sensor
  • Posted 11 Nov 2015 08:32
  • By Roibeard
  • Dublin, Ireland
Mobicon 2T
Crown CG33P5
Mobicon 2T
Crown CG33P5
