BT LPE200 Error e106
HI there
I have a BT LPE 200 which uses the curtis 1243 sep ex controller
I have had this error code e106 appear a few times after the customer charged the battery without topping it up. it states over field problem. Now it has failed completely, the truck powers up ok as soon as i try drive it, then it drops out the line with error e106.
I was thinking along the lines controller fault however have had the controller stripped and checked seems ok. I have been told it may be the battery causing the problems ( even though battery reads ok).
Has anyone come across this problem before related to the battery and this error?
Regards
  • Posted 18 Apr 2012 02:43
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hi and thanks for the advice
I have asked the customer to get the battery people out to it first just to make sure everything is ok in that department first.
Will update once confirmed.
  • Posted 19 Apr 2012 01:43
  • By elektrodrive
E106
Description
Digital outputs short-circuited or exceeding field current limit.
Possible error cause:
Problem regulating the field current.
Internal monitoring error.
Action
1.Check the output for main contactor K10 (A1/4), check cabling and contacts and measure ohms for the coil. Value 25-30 ohm. Check the output for the brake coil K10 (A1/3), check cabling and contacts and measure ohms for the coil. Value 13-15 ohm.
2.Check the output for horn (A1/7), check cabling and contacts.
3.Check the drive motor's shunt winding and cabling and contacts. Unfortunately it is not possible to measure ohms for the field winding using a standard universal instrument, since the winding has a value as low as 0.3 ohm.
Remember that a worn out / defective battery causes all sorts of odd errors to show up on a CAN BUS system like this.
  • Posted 18 Apr 2012 03:58
  • Modified 18 Apr 2012 04:00 by poster
  • By Forkingabout
  • england, United Kingdom
Hi electrodrive.
I had once a similar problem in a LPE 200\8 and the main contactor was "welded".had to replace the contacts and the PTC resistor (was burned to).
Does the pump motor runs ok?
  • Posted 18 Apr 2012 03:41
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
Toyota 4FD240
TCM FD80Z7
TCM FD80Z7 1990
Muncie, IN, United States
Deborah Baker Deborah Baker
Toyota 4FD240
TCM FD80Z7
TCM FD80Z7 1990
Toyota 4FD240
TCM FD80Z7
TCM FD80Z7 1990
