Blown Fuse
This reach truck continually blows fuses every one or two days. Fuse 5 SFE-14, serial #W91416. It happens when the forks are extended.
  • Posted 21 May 2008 00:54
  • Modified 21 May 2008 02:28 by administrator
  • By albert_h
  • joined 22 Aug'06 - 59 messages
thanks for the help, I did find a cable in the mast that was causing the short. It had been previously repaired with butt connectors. The butt connector was continually smashed against the frame when the forks were retracted, causing the coating to wear out on the connector and causing the short.
  • Posted 28 May 2008 00:09
  • By albert_h
Look for shorts in the mast cable. Look for shorts in the cable that runs from the carriage through the pantograph to the solenoid valves out on the fork carriage. Look for shorts from any part of the electrical system to the frame of the truck.
  • Posted 24 May 2008 10:47
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
UN Forklift FBRS15KQZ2
Enforcer FD50T-MMA
edition #1237 - 3 July 2025
Load Lifter LABORER-SERIES6.000LB
Flesherton, Ontario, Canada
Mitsubishi FGE35AT
