Hi a bit of a newbie to forklifts and this site so please be gentle.
we currently have an old Atlet 125 t 280LSB Pedestrian pallet lifter on-site and we are looking to convert this from a standard pallet lifter to a reel turning unit by adding a Meyer Paper Reel Clamp.
i know we have the 2 extra hydraulics to run the clamp but i'm not quite sure on the the class of the mount to the cradle and if the clamp and a 450kg reel of paper would be safely within the lifting capacity.
the spec for the clamp are:-
360 degree swivel
lift capacity - 1000 kgs
opening range - 1190 mm
clamp weight - 410 kgs
fits 16" carriage - class 2A
any help and advice is greatly received, cheers.
Resection of the superior mesenteric artery (SMA) during pancreatectomy is performed infrequently and is undertaken with the aim of removing non-metastatic locally advanced pancreatic tumours.
Hi Rob, andy is right you can not put on attachment like paper clamp on this unit, is not safe, if you want to used a paper clamp get a diferent truck biger unit like 4k kg capacity remenber safety first,
Hi Rob, I think you need a bigger truck, you will be operating on the limit of this machine at ground level. plus you are going to have major problems at height. the mast wont last long or the hydraulics
