AIR COOLED ENGINES GAS SYSTEM
Hi after some help on a 3 cylinder air cooled deutz engine in a linde. the gas system is a impco cobra (not orginal i think?). the gas regulater is heated by the exhaust gases.
when frist visited late one afternoon the regulater was frezzing stright away and runnning poorly,
changed cobra system and truck ran well but system still cold to touch.
So my questions are is this common for air cooled engines to have gas system to be cold to the touch?
The only idea i had was to restrit the exhaust gases through the regulater to heated it up more?
any advice with be great.
  • Posted 12 Jan 2013 07:39
  • By bing098
  • joined 2 Mar'12 - 40 messages
  • Kent, United Kingdom
The air warmed vaporizers I use are the Century or Zenith. I'm not familiar with an air warmed Cobra. With the correct vaporizer, the warm air from the cooling fan that keeps the engine cool warms the vaporizer nicely- it's warm to the touch.
I've seen some systems where they use a Zenith air warmed high pressure regulator, then the fuel goes to a standard Model J or Cobra (w/ no coolant flow or warm air keeping it warm), then to the mixer. Those systems work very well also.
  • Posted 13 Jan 2013 10:26
  • By bbforks
Freezing up can mean it is allowing too much fuel to exit, and running poor would confirm this. If the new regulator is running ok I suspect it would be fine to be cool to the touch. I once saw a small AC engine with an Impco regulator that had antifreeze installed in a closed loop hooked into both coolant ports and it did great.
  • Posted 12 Jan 2013 09:06
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Terberg YT222
Kalmar-Ac P100CXD
