Aid code error
hi,
We have a forklift BT it will change the main control card and trajeta hydraulic control. gives us a code C016 and there are no moves or move the hydraulic
please help.
  • Posted 8 Nov 2008 06:04
  • By andres_j
  • joined 8 Nov'08 - 1 message
  • santiago, Chile
has to be good
c16,, code on rrm 16..may i asked you,this model is ac motor or not,and this model can be program using by a CAN KEY??? if it is that is easy 1st insert the can key to can bus and goto parameter 38 and set it to 1 and off the machine and turn it again on..remember do not press the accelarator pedal once you calibrate the machine..thank you i hope you solve it asap thank you and regards
  • Posted 16 Feb 2009 18:54
  • Modified 19 Feb 2009 13:10 by poster
  • By zarci
  • joined 16 Feb'09 - 31 messages
  • ncr, Philippines
cesar
Code CO16 indicates: Voltage from accelerator pedal's potentiometer R1 is outside the calibrated value at start up.
(+/-0.2V).
Check nothing is restricting accelarator from returning to neutral position.
  • Posted 21 Nov 2008 21:13
  • By Leon_W
  • Tyne & Wear, United Kingdom
Crown WP302020
Terberg YT223
