A5 error code
Hi guys, got two of these trucks on same site with same fault.
Both will show error A5 but only if you key up the truck after the battery has been plugged in for a long period, maybe 30 minutes or so.
If you've just plugged in the battery and keyed up error code never shows, if you leave ignition on all day error code never shows, hop on/off truck all day and it's fine but switch it off and go to lunch it'll always code up A5 when you re-key, to clear code customer unplugs battery for maybe 5-10 seconds and starts over again.
I'm wondering if it's a capacitor issue in the hydraulic controller or a key switch back feed issue, I've no wiring diagram or fault code manual but I'm drawn to these two areas first.
Thanks.
  • Posted 9 Dec 2022 02:49
  • By Forking_Around
  • joined 17 Jun'21 - 43 messages
  • New Zealand
Yip, I found it the following day, both of them had been by-passed
Cheers for getting back to me though, appreciate that.
  • Posted 12 Dec 2022 03:26
  • By Forking_Around
  • New Zealand
Check your seatswitch, mostly someone bridged it.
  • Posted 11 Dec 2022 22:20
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Crown RR5225-30TT321
Unicarriers FD80-2
Hawker Powersource, Inc.
Unicarriers FD80-2
