8fgcu25 tilt solenoids open at same time.
Tilting back or forward both solenoids are working at the same time so neither function works. Any help? Previous to this the machine was tilting by itself.
  • Posted 21 Feb 2015 04:06
  • By paul10
  • joined 18 May'12 - 15 messages
I had this problem once one of the tilt cyl's was leaking internally causing pressure lock
  • Posted 17 Feb 2023 11:28
  • By M_Faus
  • joined 3 Jun'22 - 3 messages
  • Oklahoma, United States
Standard display, no finger tips control.
  • Posted 23 Feb 2015 23:06
  • By paul10
I think a little more detail will be required for anyone to help you.
serial #, fingertip controlled? upgraded display or standard?
  • Posted 21 Feb 2015 23:45
  • By stam
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Toyota 02-2TD20
UN Forklift FD40T
