Extend the life of your batteries
- 13 Jun 2019 ( #927 )
Battery Supplies recently added two excellent desulfators to their range. These handy and compact devices ensure a drastic reduction of battery degradation, this means:
  • No voltage drop of the battery.
  • Increased efficiency and reliability of the battery.
  • Green: batteries can be used up to 3 times longer, where they are otherwise discarded.
HD648
HD648
VEES
VEES
Operation:
The battery desulfators employ a Patented Dual Pulse Technology which uses a targeted method of inducing a total of 10 600 pulses per second into the battery. 5300 pulses of current per second are extracted from the battery after which the finely tuned Pulse Wave is created and induced back into the battery at the same rate of 5300 per second.
This super-efficient dual action targets crystallized inactive material, re-energizing it back into active service leaving the battery in as new condition. The high frequency pulses act as a Pace-Maker for the battery and the electrical system, restoring efficiency and reliability.
The battery desulfators are very efficient using only 10 milliamp of power which it derives from the battery itself therefore does not require external power input. Each unit can condition up to 1500Ah of battery capacity from 6v to 48v, and for larger banks multiple units can be installed in series configuration.
The desulfators operate at voltages from 6 to 48V and there are 2 versions, these for small to medium applications and those for medium to large applications. More info can be found in the flyer that you can download here.
Battery Supplies N.V.
+32 (0) 56 617 977
Send an email
www.batterysupplies.be
