wiper driver code???
I have a 524238-4 wiper driver code it says for rear wiper but neither the front or rear wiper will work. Does anyone know where these drivers are stored? Cluster??? Or could one one the wiper motors be shorted out causing the other to fail???? i am going to isolate each motor but figured it cant hurt to ask.....Thanks
  • Posted 30 Sep 2019 22:25
  • By POWERSHOP1804
  • joined 16 May'19 - 17 messages
  • New Jersey, United States
Gentlemen,
I know there was a problem with the wiper system, if it was not operational, light would not start. I also know they came out with a program fix for it in the older lifts. You will need a dealer to come out and update program. Thanks
  • Posted 4 Dec 2025 04:42
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
My manual says its the rear wiper motor??
There is a relay in the roof headlining, just check that first, I had one that was throwing a windscreen washer motor fault and it was the relay.
Its like a double sided relay you can turn it 180 degrees in the socket from memory.
  • Posted 18 Nov 2025 02:23
  • Modified 18 Nov 2025 02:27 by poster
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
I know you posted this quite a long time ago, but I'm having the problem also. The manual actually says to replace the front wiper motor. Which I did. Still has the code front and rear wiper do not work. 524238-4. Love to know what you did to solve this
  • Posted 17 Nov 2025 06:29
  • By adam_n
  • joined 7 Sep'17 - 10 messages
  • Utah, United States
An
Maxlion FB30LI
TCM FHD105Z
