Trouble with Mule pallet lift
On start up no beep display only shows picture on steering handle won't move or lift only horn blows
  • Posted 24 Feb 2021 21:10
  • By GaTech
  • joined 24 Feb'21 - 1 message
Thanks in advance
Add one more check. At the bottom of the handle, there may be two switches instead of the proximity switch. Make sure you here a click when the handle goes back to the raised position. If not, switch might have failed.
  • Posted 19 Mar 2021 06:29
  • By Fishmech
  • Virginia, United States
Without a serial number, hard to know what to check. If all you see is a picture of the handle in the display, it is telling you to let the handle up so jack can complete start up checks. If the display is still showing this, check the proximity switch at the bottom of the handle, should have a light lit on one side when you slide a piece of metal across the sensor. If the sensor lights, check all switches in the handle head, make sure none are stuck in the down position. Also, make sure the throttle is in the neutral position. Good Luck
  • Posted 19 Mar 2021 06:26
  • By Fishmech
Crown RD572513TT6860R
Crown WP302020
Zhejiang UN Forklift Co., Ltd
