toyota 7fbcu20 error codes
The forklift was error code a1-6, a1-5 and 67-1
  • Posted 10 Jun 2011 00:34
  • By ekindle
  • joined 10 Jun'11 - 2 messages
  • Arkansas, United States
near the levers / rods that move when you pull the lift handle. if you remove the plastic covers on the right side you can see them. there may be a second on on the rod behind the toe board that works on the lift lever if the unit has chopper option.
  • Posted 18 Jun 2011 08:21
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
Where is a6-1 switch located.
  • Posted 18 Jun 2011 04:43
  • By ekindle
it might be that you have the numbers transposed and if so A5-1 is a jumped seat switch. A6-1 is a lift switch on when battery was plugged in. if it is A6-1 the unit will noit lift untill its repaired.
  • Posted 10 Jun 2011 12:29
  • By toyzilla
67-1 Lifting height switch abnormality. a1-6,a1-5 non listed codes
  • Posted 10 Jun 2011 04:41
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
Aichi SR18A
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
