Toyota 7FBEHU18 Serial# 10347
Showing codes 30-1, 30-2, and 30-3. Lift operates then cuts out. Can anyone tell me what these are for or supply me with a code list. Thanks for the help. E-mail is in my profile.
  • Posted 7 Jun 2011 05:33
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
if its not the battery the line contactor is probably not closing all the way or tips are bad. to check it remove the right side cover, turn the key on and reach in and push the contactor...if it moves and locks in you could have a cpu problem, it pulls in at battery voltage then drops to a much lower voltage to hold. if it misses the first part of that process it wont pull in tight. if it doesnt move replace the contact tips. if it does.....get your wallet off of it's leash. i can give you some options if you are handy with soldering iron and pc perf board.
  • Posted 7 Jun 2011 10:47
  • Modified 7 Jun 2011 10:50 by poster
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
30-1 traveling AC driver 1 voltage low
30-2 traveling AC driver 2 voltage low
30-3 Material handling AC driver low voltage
Check fuse 1 and P3 cable but it sounds like johnr is right you probably got a bad battery
Hope this helps
  • Posted 7 Jun 2011 08:21
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
Can't help you with the meaning of the codes. But you stated "Lift operates then cuts out." This might just suggest the battery is low on charge and the unit is in the lift interrupt mode typically the battery has been discharged 80%.
Put the battery on charge over night & see what happens. If it still acts the same measure voltage of the battery if an 18 cell battery (nominally 36 v) you should get a reading of about 39 to 40 volts across the battery.
  • Posted 7 Jun 2011 05:56
  • By johnr_j
"Have An Exceptional Day!"
UN Forklift FL20-32LNJX2
Maxlion R2D25
