Hyster S80Xm No start
Working on S80XM E004V019532 TURN KEY NOTHING Battrey good -relays gd took the starter out check out ok notice with the dash board only the battery light is dim and no other lights indicated it looks like the problem maybe in the fuse box.Should I jump start starter?
any help!!
  • Posted 25 Feb 2011 03:16
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
ensure wiring to dash is not crushed along frame area along right side
  • Posted 26 Feb 2011 03:37
  • By bryan
  • joined 19 Oct'10 - 9 messages
I had a problem with a S50XM. Check to see if you have a Neg battery feed to the start relay. The ground wire somtimes breaks. My problem was the wire that connected to the engine
  • Posted 25 Feb 2011 07:11
  • By Prentice
