Bendi-Flexi-AM
I am a warehouding company, looking to better utilise floorspace, went down the turret truck path but our buildings to small/awkward to utilise efficiently.
We currnrtly use reach trucks but 3mt isles are a waste.
Has anyone got experience with the articulated types Bendi/ Flexi/ Aisle master, especially service and parts backup in Australia, seems like the agents here dont seem to stay agents for long which rings bells.
Also adverts seem to indicate upwards of 1.6mt isles, seems like that would be too tight to be efficient, anyone have experience with what is a practicle isle width?
We have a fast turnover of stock so speed of handling is quite important.
  • Posted 9 Jan 2011 14:56
  • Modified 9 Jan 2011 14:59 by poster
  • By stustu
  • joined 9 Jan'11 - 11 messages
  • Queensland, Australia
Aisle Master are supported by Adapt a Lift in Australia.
They're probably the biggest forklift dealer in Australia and they also supporting Hyster, Combilift & Agria.
www. aalhyster. com. au
www. combilift. com. au
  • Posted 24 Jan 2011 23:52
  • By RPM7
  • joined 9 Feb'06 - 5 messages
  • Monaghan, Ireland
StuStu
Bendi is supported in Australia by..............you guessed it, Bendi Australia. There have been some unsuccesful dealers in the past but these guys really know what they are doing are are fully committed to after sales support. You can contact them at [email address removed] or 1300 462 363. If you are looking to save space the Bendi can genuinly work in 1900mm aisles with Australian Pallets and the trucks work great outside too. Don't take my word for it, give them a call and go see some customers that are raving about the product.
  • Posted 21 Jan 2011 09:23
  • By Sceptic1
  • joined 6 Jun'09 - 6 messages
  • Worcestershire, United Kingdom
I would also suggest a consideration of how often your operators will be on and off the machines, and if your operation requires a lot of getting off the machine, then consider a "stand up counter balanced" unit some times called "dock stocker" style unit.
  • Posted 14 Jan 2011 21:40
Seems to me you are working on this bass ackwards. You have fast throughput but want space efficiency and to squeeze every last drop out of not good buildings.
1. Can you consolidate into a good/or purpose built built building
2. Is speed more important than space, if so you'll have to give up one or have a mixed solution. Use one type of truck captive to aisle and one type to load trucks. Have some sort of P&D interface between them.
3. If not then Aislemaster is great solution because it does both,built like a brick shithouse out of off the shelf OEM parts and it works.
I don't sell them I do racks but I have a customer who went to them about 3 years ago and loves them. A lot of these machines are as delicate as Ferrari's (Bendi waiting for parts from UK) but this thing is like a rock crawling jeep.
  • Posted 14 Jan 2011 04:07
  • By andrew_j
  • joined 20 Feb'09 - 54 messages
I learn from my customers and mistakes
would agree with andypandy flexi have 2 control panels ge or zappi so controller shouldnt be a problem in australia
  • Posted 13 Jan 2011 06:16
  • By sullyamg
  • joined 13 Mar'08 - 9 messages
The Aislemaster is by far the most reliable, very simple to work on not sure type of support you have in Australia.
  • Posted 10 Jan 2011 07:15
  • By Leon_W
  • Tyne & Wear, United Kingdom
Grubbymits has a point but if you are looking to save space and increase your capacity they are an option. Just be aware that they do need more looking after than a normal machine and subsequently cost more to run. If i had to go with one of the 3 mentioned i would go with the Flexi.
  • Posted 10 Jan 2011 07:06
  • By AndyPandy
i wouldn,t have an articulated truck of any kind near my operation. costly and unreliable junk.stick with your reach trucks
  • Posted 9 Jan 2011 19:39
  • By grubbymits
  • joined 25 Jan'09 - 49 messages
  • scotland, United Kingdom
