NICHIYU FBT18P
Can somebody help me find solution for hard to steer electric Nichiyu FBT18P. Fuses are okey, but the steering motor is not actuating when you turn steering wheel. Am I replacing EPS Unit or potentiometer? Appreciate your kind reply.
Thank you.
  • Posted 13 Nov 2010 12:00
  • By MIAN-MAVI
  • joined 23 Oct'08 - 9 messages
  • Manila, Philippines
Steering problem is solved as per your recommendation. I replaced the chain and steering function back to normal.
  • Posted 15 Nov 2010 18:41
  • By MIAN-MAVI
I will do further check as per your advise, Thanks Bjarte
  • Posted 15 Nov 2010 07:01
  • By MIAN-MAVI
I will do further check as per your advise. Thanks Mark
  • Posted 15 Nov 2010 06:59
  • By MIAN-MAVI
Hi Rex, you should check the chain under batterybox. it rust alotand will be stiff.
  • Posted 15 Nov 2010 06:33
  • By bjarte
  • joined 24 Sep'09 - 63 messages
  • 5911 Alversund, Norway
post at 2talservice dot no
Hello Rex, well if the display doesn't show any error messages it is probably the motor. Please control if the small EPS contactor closes when you switch on the contact. If you have an amp clamp control if there isn't any current on the EPS motor while turning on the steering wheel.
Regards
Marc
  • Posted 15 Nov 2010 00:17
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Hi Marc, model is (FBT18P-65Series). No error message shown on the display, but the unit is driving & hydraulics are working too.
  • Posted 14 Nov 2010 18:51
  • By MIAN-MAVI
Hello Rex, can you give up the complete model (FBT18PN-75) and are there error message on the display?
Kind regards
Marc
  • Posted 14 Nov 2010 18:08
  • By marc_b
  • ANTWERP, Belgium
Maxlion FDR45
Elwell-Parker ESI500-36
Maxlion FDR45
